Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
Vmix v23.0.0.46 When I select outputs to record, which may not be all of them I get files recorded for unchecked inputs in multicorder. For instance 2x VMIX calls I am routing to outputs 3+4 (for consistent frame rate etc) outputs are checked, but the vmix call inputs are not and are also recording, even though not selected. Also the case for an input on one of the capture cards. recording even though not selected. I am doing a large number of recordings, each gets a test session with record paths and selected inputs to be recorded but this appears not to be consistently working.
