2 Pages<12
ayo
#21 Posted : Monday, April 27, 2020 11:12:00 PM(UTC)
ayo
Originally Posted by: IceStream Go to Quoted Post
@ PFBM
vMix to vMix Call uses WebRTC (better audio options)
Chrome to VMix Call uses WebRTC (restricted audio)
Which app is at fault here?
It is not possible to “overwrite” Chrome’s coding...
Hello Ice.
The current bitrate chrome->vMix is 64kbits OPUS, that is like 128kbits known common mp3. That could be OK.
The thing that ruins music is the sound processing in the browser, applied for noise reduction and echo cancelling. We have tried another service also with Chrome and got no sound processing, also found multiple dev forums discusing how to disable stream processing in a web client, so we ask vMix to implement code to be able to disable sound processing for a guest in the same way we can modify their bandwidth... That would be an awesome improvement in my opinion
IMPORTANT: I think no one is saying vMix is fault, its great and we are trying to make it better :-)
Thanks for your time!
thanks 1 user thanked ayo for this useful post.
PFBM on 4/27/2020(UTC)
PFBM
#22 Posted : Monday, April 27, 2020 11:50:28 PM(UTC)
PFBM
check the power of high quality opus :
https://now.source-elements.com
Cheers,
PFBM
Guest (11)
2 Pages<12
