Powerpoint input - Change slide timing
Is it possible change the individual slide timings from a powerpoint? Now all slides are in my case on 20 seconds.
Or is it possible to take the slide timings already setup in powerpoint itself instead of the settings in vMix?
Kind Regards, Hylke
Simple answer to both questions. No.
Log a FR with a use case if you want to see this changed.
