NDI
Desktop Capture and NDI
Joined: 3/24/2020(UTC) Posts: 29  Location: Burlingame, CA Was thanked: 5 time(s) in 3 post(s)
Theoretically speaking, using a Laptop with i7-6core, 32GB RAM, GTX 1650 Video Card and Gigabit Ethernet,
How many PCs running desktop capture would you be able to bring in via NDI and create Multiple Multiviewers?
Joined: 1/25/2019(UTC) Posts: 332  Thanks: 24 times Was thanked: 85 time(s) in 65 post(s)
Assuming that VMIX uses 1080/30p Full NDI, one can assume that 4 sources (Laptops) can be used in a Gigabit network. Normally the Laptops use the same network as for the Internet. Depending on the used internet bandwidth, the remaining bandwidth for NDI is reduced again. Here is an easy to understand NDI bandwidth table
NDI
