ticker
#1 Posted : Sunday, April 12, 2020 5:37:45 PM(UTC)
ticker
Hey all have noticed quite a few times when we start our program (by hitting a shortcut connected to the show opener, which triggers the record start on transition in) - the start of the record seems to miss the first few seconds. Sometimes 1, sometimes up to 5 seconds is clipped off at the start.
Our system is above the hardware specs. We have tried many things but can't work out the problem.
#2 Posted : Sunday, April 12, 2020 6:00:45 PM(UTC)
Might be better to change the order:
shortcut recording -> transition opener ?
ticker
#3 Posted : Sunday, April 12, 2020 10:53:35 PM(UTC)
ticker
Yeh I've got it that way. I think it's because I have a stop recording above it. It goes SDTOP, then START, so I can force cut the program into parts to be used for different things. I assume it takes a few seances to write the previous record before starting the new one.
dmwkr
#4 Posted : Monday, April 13, 2020 3:27:11 AM(UTC)
dmwkr
You could add a Sleep command between stop and start.
