folgersb
#1 Posted : Sunday, April 5, 2020 10:12:18 AM(UTC)
folgersb
Our church just started live streaming 3 weeks ago. Our streaming software consist of vMix and Propresenter 7. We have been learning new stuff each week but wanted to reach out regarding the options for having text automatically resize. We are sending lyrics/scriptures from propresenter to Vmix through a NDI specifically for lower thirds. We then have this overlay set on our main cameras so the lyrics/scriptures are displaying on the lower thirds. Lyrics are fine because they are edited beforehand to include 2-3 lines at max so they display correctly on the lower thirds. Scriptures are typically pulled on the fly from the Bible feature within propresenter and then sent to Vmix immediately. So depending on the size of the scripture and the font set in propresenter, if the scripture is more than 5 lines let say, some part of the scripture is cut off on the live feed until the operator manually adjust the settings within vmix. So we are looking for a way to have the text that is sent from propresenter to the vMix/NDI lower third automatically adjust within the lower thirds box that has been created. We haven't had any luck locating an option so I wanted to reach out. Hopefully this description makes sense. Thank you.
