Hello Vmix team
i accidentally stopped my last stream from Facebook before stopping the stream button in vMix. Today i tried streaming again but everytime i click golive in Facebook, i get a message "error starting broadcast please try again".
I AM STUCK
This is the last log file
ffmpeg started on 2020-04-04 at 12:00:59
Report written to "C:\ProgramData\vMix\streaming\streaming1 20200404-120058.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg2.exe" -report -rtbufsize 128M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1920x1080 -pix_fmt:v yuv420p -threads 4 -bufsize:v 3000k -g:v 50 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 3000k -maxrate:v 3300k -codec:a aac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/23.0.0.46)" -f flv "rtmps://live-api-s.facebook.com:443/rtmp/2431858310369900?s_bl=1&s_sc=2431858323703232&s_sw=0&s_vt=api-s&a=AbwoimGwlg9WpMJw"
ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers
  built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
  configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686
  libavutil      55. 76.100 / 55. 76.100
  libavcodec     57.106.101 / 57.106.101
  libavformat    57. 82.101 / 57. 82.101
  libavdevice    57.  8.101 / 57.  8.101
  libavfilter     6.105.100 /  6.105.100
  libswscale      4.  7.103 /  4.  7.103
  libswresample   2.  8.100 /  2.  8.100
  libpostproc    54.  6.100 / 54.  6.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
  Duration: N/A, start: 522662.978000, bitrate: 1536 kb/s
    Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1920x1080, 25 fps, 25 tbr, 10000k tbn, 10000k tbc
    Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
[tcp @ 04afd680] TCP Buffer has been set to 7820288 bytes
[dshow @ 029b7f20] real-time buffer [vMix Video YV12] [video input] too full or near too full (63% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 029b7f20] real-time buffer [vMix Video YV12] [video input] too full or near too full (70% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 029b7f20] real-time buffer [vMix Video YV12] [video input] too full or near too full (75% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 029b7f20] real-time buffer [vMix Video YV12] [video input] too full or near too full (80% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 029b7f20] real-time buffer [vMix Video YV12] [video input] too full or near too full (85% of size: 128000000 [rtbufsize parameter])! frame dropped!
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
  Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (native))
Press [q] to stop, [?] for help
[libx264 @ 04af9380] frame MB size (120x68) > level limit (3600)
[libx264 @ 04af9380] MB rate (204000) > level limit (108000)
[libx264 @ 04af9380] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
[libx264 @ 04af9380] profile Constrained Baseline, level 3.1
[libx264 @ 04af9380] 264 - core 152 - H.264/MPEG-4 AVC codec - Copyleft 2003-2017 -
http://www.videolan.org/x264.html - options: cabac=0 ref=1 deblock=1:0:0 analyse=0x1:0x111 me=hex subme=2 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=4 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=0 weightp=0 keyint=50 keyint_min=5 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=abr mbtree=1 bitrate=3000 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=3300 vbv_bufsize=3000 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00
Output #0, flv, to 'rtmps://live-api-s.facebook.com:443/rtmp/2431858310369900?s_bl=1&s_sc=2431858323703232&s_sw=0&s_vt=api-s&a=AbwoimGwlg9WpMJw':
  Metadata:
    encoder         : Lavf57.82.101
    Stream #0:0: Video: h264 (libx264) ([7][0][0][0] / 0x0007), yuv420p, 1920x1080, q=-1--1, 3000 kb/s, 25 fps, 1k tbn, 25 tbc
    Metadata:
      encoder         : Lavc57.106.101 libx264
    Side data:
      cpb: bitrate max/min/avg: 3300000/0/3000000 buffer size: 3000000 vbv_delay: -1
    Stream #0:1: Audio: aac (LC) ([10][0][0][0] / 0x000A), 48000 Hz, stereo, fltp, 128 kb/s
    Metadata:
      encoder         : Lavc57.106.101 aac
frame=   43 fps=0.0 q=28.0 size=     433kB time=00:00:02.11 bitrate=1681.2kbits/s speed= 4.2x
frame=   59 fps= 59 q=27.0 size=     788kB time=00:00:02.75 bitrate=2346.1kbits/s speed=2.74x
frame=   72 fps= 48 q=28.0 size=    1053kB time=00:00:03.24 bitrate=2661.8kbits/s speed=2.15x
frame=   85 fps= 42 q=28.0 size=    1223kB time=00:00:03.75 bitrate=2670.1kbits/s speed=1.86x
frame=   97 fps= 38 q=28.0 size=    1404kB time=00:00:04.26 bitrate=2697.6kbits/s speed=1.69x
frame=  110 fps= 36 q=28.0 size=    1629kB time=00:00:04.77 bitrate=2794.1kbits/s speed=1.58x
frame=  123 fps= 35 q=29.0 size=    1875kB time=00:00:05.26 bitrate=2916.6kbits/s speed=1.49x
frame=  135 fps= 33 q=29.0 size=    2039kB time=00:00:05.77 bitrate=2890.8kbits/s speed=1.43x
frame=  148 fps= 33 q=28.0 size=    2220kB time=00:00:06.29 bitrate=2891.4kbits/s speed=1.38x
frame=  161 fps= 32 q=28.0 size=    2410kB time=00:00:06.78 bitrate=2911.2kbits/s speed=1.34x
frame=  173 fps= 31 q=28.0 size=    2614kB time=00:00:07.29 bitrate=2935.5kbits/s speed=1.32x
frame=  186 fps= 31 q=28.0 size=    2776kB time=00:00:07.78 bitrate=2921.9kbits/s speed=1.29x
frame=  198 fps= 30 q=28.0 size=    2998kB time=00:00:08.31 bitrate=2953.1kbits/s speed=1.27x
frame=  211 fps= 30 q=29.0 size=    3301kB time=00:00:08.80 bitrate=3070.3kbits/s speed=1.25x
frame=  223 fps= 29 q=30.0 size=    3523kB time=00:00:09.29 bitrate=3103.8kbits/s speed=1.23x
frame=  236 fps= 29 q=29.0 size=    3656kB time=00:00:09.81 bitrate=3053.4kbits/s speed=1.22x
frame=  249 fps= 29 q=30.0 size=    3871kB time=00:00:10.32 bitrate=3071.8kbits/s speed= 1.2x
frame=  261 fps= 29 q=31.0 size=    4146kB time=00:00:10.83 bitrate=3134.6kbits/s speed=1.19x
frame=  274 fps= 29 q=31.0 size=    4366kB time=00:00:11.32 bitrate=3157.8kbits/s speed=1.18x
frame=  287 fps= 28 q=30.0 size=    4521kB time=00:00:11.83 bitrate=3128.6kbits/s speed=1.17x
frame=  299 fps= 28 q=30.0 size=    4634kB time=00:00:12.35 bitrate=3073.8kbits/s speed=1.17x
frame=  312 fps= 28 q=29.0 size=    4785kB time=00:00:12.84 bitrate=3052.7kbits/s speed=1.16x
frame=  324 fps= 28 q=29.0 size=    4881kB time=00:00:13.35 bitrate=2994.8kbits/s speed=1.15x
frame=  337 fps= 28 q=28.0 size=    5005kB time=00:00:13.84 bitrate=2961.9kbits/s speed=1.14x
frame=  350 fps= 28 q=27.0 size=    5154kB time=00:00:14.35 bitrate=2941.2kbits/s speed=1.14x
frame=  363 fps= 28 q=27.0 size=    5358kB time=00:00:14.86 bitrate=2952.5kbits/s speed=1.13x
frame=  375 fps= 28 q=27.0 size=    5508kB time=00:00:15.35 bitrate=2937.8kbits/s speed=1.13x
frame=  388 fps= 27 q=27.0 size=    5685kB time=00:00:15.87 bitrate=2934.4kbits/s speed=1.12x
frame=  400 fps= 27 q=27.0 size=    5845kB time=00:00:16.38 bitrate=2922.7kbits/s speed=1.12x
frame=  413 fps= 27 q=27.0 size=    6082kB time=00:00:16.89 bitrate=2949.0kbits/s speed=1.12x
frame=  426 fps= 27 q=26.0 size=    6250kB time=00:00:17.38 bitrate=2945.5kbits/s speed=1.11x
frame=  438 fps= 27 q=26.0 size=    6419kB time=00:00:17.89 bitrate=2938.5kbits/s speed=1.11x
frame=  451 fps= 27 q=26.0 size=    6616kB time=00:00:18.40 bitrate=2944.4kbits/s speed=1.11x
frame=  463 fps= 27 q=27.0 size=    6864kB time=00:00:18.89 bitrate=2975.3kbits/s speed= 1.1x
frame=  476 fps= 27 q=26.0 size=    7045kB time=00:00:19.41 bitrate=2973.5kbits/s speed= 1.1x
frame=  489 fps= 27 q=26.0 size=    7231kB time=00:00:19.90 bitrate=2976.5kbits/s speed= 1.1x
frame=  501 fps= 27 q=26.0 size=    7409kB time=00:00:20.43 bitrate=2970.1kbits/s speed=1.09x
frame=  514 fps= 27 q=26.0 size=    7675kB time=00:00:20.92 bitrate=3004.4kbits/s speed=1.09x
frame=  527 fps= 27 q=26.0 size=    7867kB time=00:00:21.43 bitrate=3006.1kbits/s speed=1.09x
frame=  539 fps= 27 q=26.0 size=    8041kB time=00:00:21.95 bitrate=3000.9kbits/s speed=1.09x
frame=  552 fps= 27 q=26.0 size=    8230kB time=00:00:22.44 bitrate=3004.5kbits/s speed=1.08x
frame=  565 fps= 27 q=27.0 size=    8489kB time=00:00:22.95 bitrate=3030.0kbits/s speed=1.08x
frame=  577 fps= 27 q=26.0 size=    8660kB time=00:00:23.44 bitrate=3026.4kbits/s speed=1.08x
frame=  590 fps= 27 q=26.0 size=    8847kB time=00:00:23.95 bitrate=3025.6kbits/s speed=1.08x
frame=  602 fps= 27 q=26.0 size=    9022kB time=00:00:24.46 bitrate=3020.8kbits/s speed=1.08x
frame=  615 fps= 26 q=27.0 size=    9283kB time=00:00:24.95 bitrate=3047.0kbits/s speed=1.07x
frame=  628 fps= 26 q=26.0 size=    9468kB time=00:00:25.47 bitrate=3045.3kbits/s speed=1.07x
frame=  640 fps= 26 q=26.0 size=    9647kB time=00:00:25.96 bitrate=3044.1kbits/s speed=1.07x
frame=  653 fps= 26 q=23.0 size=    9838kB time=00:00:26.49 bitrate=3042.0kbits/s speed=1.07x
frame=  665 fps= 26 q=27.0 size=   10077kB time=00:00:26.98 bitrate=3059.4kbits/s speed=1.07x
frame=  678 fps= 26 q=26.0 size=   10261kB time=00:00:27.49 bitrate=3057.0kbits/s speed=1.07x
frame=  690 fps= 26 q=26.0 size=   10442kB time=00:00:27.98 bitrate=3056.5kbits/s speed=1.07x
frame=  703 fps= 26 q=23.0 size=   10644kB time=00:00:28.47 bitrate=3061.9kbits/s speed=1.06x
frame=  716 fps= 26 q=27.0 size=   10897kB time=00:00:29.01 bitrate=3077.0kbits/s speed=1.06x
frame=  729 fps= 26 q=27.0 size=   11078kB time=00:00:29.50 bitrate=3076.1kbits/s speed=1.06x
frame=  741 fps= 26 q=26.0 size=   11243kB time=00:00:30.03 bitrate=3066.7kbits/s speed=1.06x
frame=  754 fps= 26 q=26.0 size=   11431kB time=00:00:30.52 bitrate=3067.6kbits/s speed=1.06x
frame=  767 fps= 26 q=27.0 size=   11689kB time=00:00:31.03 bitrate=3085.1kbits/s speed=1.06x
frame=  779 fps= 26 q=27.0 size=   11866kB time=00:00:31.55 bitrate=3081.1kbits/s speed=1.06x
frame=  792 fps= 26 q=27.0 size=   12062kB time=00:00:32.04 bitrate=3083.9kbits/s speed=1.06x
frame=  805 fps= 26 q=27.0 size=   12257kB time=00:00:32.55 bitrate=3084.5kbits/s speed=1.06x
frame=  817 fps= 26 q=27.0 size=   12501kB time=00:00:33.06 bitrate=3097.3kbits/s speed=1.06x
frame=  830 fps= 26 q=27.0 size=   12673kB time=00:00:33.57 bitrate=3091.9kbits/s speed=1.06x
frame=  843 fps= 26 q=26.0 size=   12847kB time=00:00:34.06 bitrate=3089.3kbits/s speed=1.05x
frame=  855 fps= 26 q=27.0 size=   13013kB time=00:00:34.55 bitrate=3084.8kbits/s speed=1.05x
frame=  868 fps= 26 q=27.0 size=   13265kB time=00:00:35.07 bitrate=3098.6kbits/s speed=1.05x
frame=  880 fps= 26 q=27.0 size=   13428kB time=00:00:35.58 bitrate=3091.6kbits/s speed=1.05x
frame=  893 fps= 26 q=26.0 size=   13614kB time=00:00:36.09 bitrate=3090.0kbits/s speed=1.05x
frame=  906 fps= 26 q=26.0 size=   13874kB time=00:00:36.58 bitrate=3106.8kbits/s speed=1.05x
frame=  918 fps= 26 q=27.0 size=   14038kB time=00:00:37.11 bitrate=3098.2kbits/s speed=1.05x
frame=  931 fps= 26 q=26.0 size=   14219kB time=00:00:37.60 bitrate=3097.3kbits/s speed=1.05x
frame=  944 fps= 26 q=26.0 size=   14410kB time=00:00:38.09 bitrate=3098.6kbits/s speed=1.05x
frame=  956 fps= 26 q=27.0 size=   14662kB time=00:00:38.63 bitrate=3109.2kbits/s speed=1.05x
frame=  969 fps= 26 q=27.0 size=   14856kB time=00:00:39.12 bitrate=3110.8kbits/s speed=1.05x
frame=  981 fps= 26 q=27.0 size=   15033kB time=00:00:39.63 bitrate=3107.2kbits/s speed=1.05x
frame=  994 fps= 26 q=27.0 size=   15217kB time=00:00:40.12 bitrate=3106.6kbits/s speed=1.05x
frame= 1007 fps= 26 q=27.0 size=   15493kB time=00:00:40.63 bitrate=3123.1kbits/s speed=1.04x
frame= 1019 fps= 26 q=27.0 size=   15676kB time=00:00:41.15 bitrate=3120.7kbits/s speed=1.04x
frame= 1032 fps= 26 q=27.0 size=   15868kB time=00:00:41.64 bitrate=3121.8kbits/s speed=1.04x
frame= 1045 fps= 26 q=27.0 size=   16074kB time=00:00:42.17 bitrate=3122.2kbits/s speed=1.04x
frame= 1057 fps= 26 q=27.0 size=   16323kB time=00:00:42.66 bitrate=3134.3kbits/s speed=1.04x
frame= 1070 fps= 26 q=28.0 size=   16551kB time=00:00:43.17 bitrate=3140.4kbits/s speed=1.04x
frame= 1083 fps= 26 q=28.0 size=   16760kB time=00:00:43.66 bitrate=3144.3kbits/s speed=1.04x
frame= 1095 fps= 26 q=28.0 size=   16956kB time=00:00:44.17 bitrate=3144.1kbits/s speed=1.04x
frame= 1108 fps= 26 q=28.0 size=   17203kB time=00:00:44.69 bitrate=3153.4kbits/s speed=1.04x
frame= 1121 fps= 26 q=28.0 size=   17396kB time=00:00:45.18 bitrate=3154.1kbits/s speed=1.04x
frame= 1133 fps= 26 q=28.0 size=   17565kB time=00:00:45.71 bitrate=3147.6kbits/s speed=1.04x
frame= 1146 fps= 26 q=28.0 size=   17732kB time=00:00:46.20 bitrate=3143.8kbits/s speed=1.04x
frame= 1159 fps= 26 q=28.0 size=   17952kB time=00:00:46.71 bitrate=3147.8kbits/s speed=1.04x
frame= 1171 fps= 26 q=28.0 size=   18098kB time=00:00:47.20 bitrate=3140.6kbits/s speed=1.04x
frame= 1184 fps= 26 q=28.0 size=   18231kB time=00:00:47.69 bitrate=3131.2kbits/s speed=1.04x
frame= 1196 fps= 26 q=27.0 size=   18399kB time=00:00:48.23 bitrate=3125.0kbits/s speed=1.04x
frame= 1209 fps= 26 q=28.0 size=   18630kB time=00:00:48.72 bitrate=3132.4kbits/s speed=1.04x
frame= 1222 fps= 26 q=27.0 size=   18786kB time=00:00:49.23 bitrate=3125.9kbits/s speed=1.04x
frame= 1234 fps= 26 q=27.0 size=   18933kB time=00:00:49.74 bitrate=3117.9kbits/s speed=1.04x
frame= 1247 fps= 26 q=27.0 size=   19101kB time=00:00:50.23 bitrate=3114.6kbits/s speed=1.04x
frame= 1260 fps= 26 q=27.0 size=   19334kB time=00:00:50.75 bitrate=3120.9kbits/s speed=1.04x
frame= 1272 fps= 26 q=27.0 size=   19482kB time=00:00:51.26 bitrate=3113.3kbits/s speed=1.04x
frame= 1285 fps= 26 q=27.0 size=   19647kB time=00:00:51.77 bitrate=3108.7kbits/s speed=1.03x
frame= 1297 fps= 26 q=26.0 size=   19813kB time=00:00:52.26 bitrate=3105.5kbits/s speed=1.03x
frame= 1310 fps= 26 q=27.0 size=   20069kB time=00:00:52.79 bitrate=3113.8kbits/s speed=1.03x
frame= 1323 fps= 26 q=27.0 size=   20243kB time=00:00:53.28 bitrate=3111.9kbits/s speed=1.03x
frame= 1335 fps= 26 q=26.0 size=   20404kB time=00:00:53.77 bitrate=3108.1kbits/s speed=1.03x
frame= 1348 fps= 26 q=26.0 size=   20612kB time=00:00:54.31 bitrate=3109.0kbits/s speed=1.03x
frame= 1361 fps= 26 q=27.0 size=   20886kB time=00:00:54.80 bitrate=3122.1kbits/s speed=1.03x
frame= 1374 fps= 26 q=27.0 size=   21060kB time=00:00:55.31 bitrate=3119.0kbits/s speed=1.03x
frame= 1386 fps= 26 q=27.0 size=   21235kB time=00:00:55.82 bitrate=3116.1kbits/s speed=1.03x
frame= 1399 fps= 26 q=27.0 size=   21424kB time=00:00:56.31 bitrate=3116.3kbits/s speed=1.03x
frame= 1412 fps= 26 q=27.0 size=   21679kB time=00:00:56.83 bitrate=3125.0kbits/s speed=1.03x
frame= 1424 fps= 26 q=27.0 size=   21837kB time=00:00:57.34 bitrate=3119.7kbits/s speed=1.03x
frame= 1437 fps= 26 q=27.0 size=   22014kB time=00:00:57.85 bitrate=3117.2kbits/s speed=1.03x
frame= 1450 fps= 26 q=27.0 size=   22196kB time=00:00:58.34 bitrate=3116.5kbits/s speed=1.03x
frame= 1462 fps= 26 q=27.0 size=   22443kB time=00:00:58.87 bitrate=3122.6kbits/s speed=1.03x
frame= 1475 fps= 26 q=27.0 size=   22618kB time=00:00:59.36 bitrate=3120.9kbits/s speed=1.03x
frame= 1488 fps= 26 q=27.0 size=   22807kB time=00:00:59.85 bitrate=3121.3kbits/s speed=1.03x
frame= 1500 fps= 26 q=27.0 size=   22970kB time=00:01:00.39 bitrate=3115.8kbits/s speed=1.03x
frame= 1513 fps= 26 q=27.0 size=   23221kB time=00:01:00.86 bitrate=3125.5kbits/s speed=1.03x
frame= 1525 fps= 26 q=27.0 size=   23383kB time=00:01:01.39 bitrate=3120.1kbits/s speed=1.03x
frame= 1538 fps= 26 q=27.0 size=   23571kB time=00:01:01.88 bitrate=3120.1kbits/s speed=1.03x
frame= 1550 fps= 26 q=26.0 size=   23742kB time=00:01:02.39 bitrate=3116.9kbits/s speed=1.03x
frame= 1563 fps= 26 q=27.0 size=   24003kB time=00:01:02.91 bitrate=3125.6kbits/s speed=1.03x
frame= 1576 fps= 26 q=27.0 size=   24192kB time=00:01:03.40 bitrate=3125.8kbits/s speed=1.03x
frame= 1588 fps= 26 q=27.0 size=   24365kB time=00:01:03.91 bitrate=3123.0kbits/s speed=1.03x
frame= 1601 fps= 26 q=27.0 size=   24553kB time=00:01:04.40 bitrate=3123.2kbits/s speed=1.03x
frame= 1613 fps= 26 q=27.0 size=   24803kB time=00:01:04.91 bitrate=3130.1kbits/s speed=1.03x
frame= 1626 fps= 26 q=27.0 size=   24981kB time=00:01:05.40 bitrate=3128.8kbits/s speed=1.03x
frame= 1639 fps= 26 q=27.0 size=   25182kB time=00:01:05.91 bitrate=3129.5kbits/s speed=1.03x
frame= 1651 fps= 26 q=27.0 size=   25380kB time=00:01:06.43 bitrate=3129.8kbits/s speed=1.03x
frame= 1664 fps= 26 q=27.0 size=   25661kB time=00:01:06.92 bitrate=3141.3kbits/s speed=1.03x
frame= 1677 fps= 26 q=27.0 size=   25865kB time=00:01:07.43 bitrate=3142.3kbits/s speed=1.03x
frame= 1689 fps= 26 q=28.0 size=   26045kB time=00:01:07.94 bitrate=3140.2kbits/s speed=1.03x
frame= 1702 fps= 26 q=27.0 size=   26230kB time=00:01:08.45 bitrate=3138.9kbits/s speed=1.03x
frame= 1715 fps= 26 q=28.0 size=   26462kB time=00:01:08.94 bitrate=3144.1kbits/s speed=1.03x
frame= 1727 fps= 26 q=28.0 size=   26629kB time=00:01:09.45 bitrate=3140.7kbits/s speed=1.03x
frame= 1740 fps= 26 q=27.0 size=   26797kB time=00:01:09.97 bitrate=3137.4kbits/s speed=1.03x
frame= 1753 fps= 26 q=24.0 size=   26965kB time=00:01:10.46 bitrate=3134.9kbits/s speed=1.03x
frame= 1765 fps= 25 q=27.0 size=   27186kB time=00:01:10.99 bitrate=3137.0kbits/s speed=1.03x
frame= 1778 fps= 25 q=27.0 size=   27372kB time=00:01:11.48 bitrate=3136.8kbits/s speed=1.03x
frame= 1791 fps= 25 q=27.0 size=   27544kB time=00:01:11.99 bitrate=3133.9kbits/s speed=1.02x
frame= 1803 fps= 25 q=24.0 size=   27706kB time=00:01:12.51 bitrate=3130.2kbits/s speed=1.02x
frame= 1816 fps= 25 q=27.0 size=   27949kB time=00:01:13.00 bitrate=3136.5kbits/s speed=1.02x
frame= 1829 fps= 25 q=27.0 size=   28114kB time=00:01:13.51 bitrate=3133.0kbits/s speed=1.02x
frame= 1841 fps= 25 q=27.0 size=   28272kB time=00:01:14.02 bitrate=3128.8kbits/s speed=1.02x
frame= 1854 fps= 25 q=27.0 size=   28452kB time=00:01:14.51 bitrate=3127.9kbits/s speed=1.02x
frame= 1866 fps= 25 q=27.0 size=   28679kB time=00:01:15.02 bitrate=3131.4kbits/s speed=1.02x
frame= 1879 fps= 25 q=27.0 size=   28850kB time=00:01:15.53 bitrate=3128.7kbits/s speed=1.02x
[flv @ 04af7e80] Failed to update header with correct duration.
[flv @ 04af7e80] Failed to update header with correct filesize.
frame= 1889 fps= 25 q=-1.0 Lsize=   29200kB time=00:01:15.98 bitrate=3148.0kbits/s speed=1.02x
video:27915kB audio:1189kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.331324%
[libx264 @ 04af9380] frame I:40    Avg QP:19.68  size: 81268
[libx264 @ 04af9380] frame P:1849  Avg QP:21.92  size: 13701
[libx264 @ 04af9380] mb I  I16..4: 78.5%  0.0% 21.5%
[libx264 @ 04af9380] mb P  I16..4: 19.8%  0.0%  0.0%  P16..4: 35.9%  2.3%  0.1%  0.0%  0.0%    skip:41.9%
[libx264 @ 04af9380] coded y,uvDC,uvAC intra: 7.4% 63.5% 10.4% inter: 2.5% 38.4% 0.1%
[libx264 @ 04af9380] i16 v,h,dc,p: 38% 37% 18%  7%
[libx264 @ 04af9380] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 36% 17%  4%  5%  4%  6%  4%  4%
[libx264 @ 04af9380] i8c dc,h,v,p: 57% 23% 19%  2%
[libx264 @ 04af9380] kb/s:3012.00
[aac @ 04afb780] Qavg: 889.363
