triggers based on time countdown?
Joined: 3/20/2019(UTC) Posts: 31  Location: San Diego Was thanked: 3 time(s) in 2 post(s)
I want to trigger overlays and transitions at specific times. I've set up countdown triggers based on the amount of time (in 30 seconds do x), which is handy but not want I need. Is it possible to set triggers based on a specific time example at 1:00 PM turn on overlay 1?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Use a script to check the time and trigger accordingly ;-)
