Hallo
For RTMP it would be better to use input flash. It works with input flash, practically no latency compared to VLC for vMix. Input stream with VLC for vMix 4x longer latency than with Flash. The problem with flash is that if the connection is lost, flash no longer starts automatically, only manually with reset. Can't you implement RTMP again in Flash that everything works? Would be a huge advantage. Thank you
Gruss
