Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
I use sport video sources recorded in HD 25p - what setting should be used in vMix if the stream is mainly to facebook - 25p or 30p? The logic should probably say 25p - but I have read that "all internet things" is optimized for 30p..but I do not know - so I ask here to be sure :) ps. I also have some recordings in 50p - should I then use 50p setting in vMix? If so - it must be important to be consistency in what I record in.... as the setting in vMix is set in general (so I can not use a mix of 25p and 50p recordings...?)
