Aahz
#1 Posted : Sunday, March 15, 2020 8:28:04 AM(UTC)
Aahz
I have added Skype as input, and i can see Skype picture, but there is no Skype sound in vMix, when a Skype audio/video call is in progress.
So, i was wondering if there is a way to configure vMix to have also Skype sound available with Skype picture?
I also could not see the internal sound card as a source in the available sound sources list, to add it in vMix.
Please see screenshots.
Thanks!
Andrew
#2 Posted : Monday, March 16, 2020 3:23:24 AM(UTC)
Andrew
Was thanked: 8 time(s) in 4 post(s)
That is probably not the best approach to your needs.
Google "Skype for Content Creators"
You can get wonderful clean NDI feeds out of Skype, of multiple callers, with independent audio.
Or use vMix call instead of Skype!
elvis55
#3 Posted : Monday, March 16, 2020 4:32:55 AM(UTC)
elvis55
Switzerland
BionicTdb
#4 Posted : Friday, March 20, 2020 12:10:41 AM(UTC)
BionicTdb
you can also just use Skype like you are and go to sound settings under recording and enable stereo mix. this mixes all PC audio sources into one.
then select stereo mix as your audio source as input.
Guest (5)
