Stingers not working on mix 2
Hi!
We have added a new mix input in vMix (sub mix nr. 2 ) but we can not get the any of the stingers to work when transition between preview and program. Both the fade, cut and all other transitions work fine, but not the stingers. Anybody has a solution for this?
Kim
We are also doing a broadcast with two different outputs, but some of the graphics is the same for both streams. The setup is the normal program output routed to external 1, and input 2 is routed to external 2, which is a submix (mix 2) Is there any way to get the same overlays on these two outputs? Or is the overlays only limited to the master output?
Kim
Joined: 1/13/2010(UTC) Posts: 5,335  Location: Gold Coast, Australia Was thanked: 4735 time(s) in 1624 post(s)
