rachyl1708
#1 Posted : Thursday, February 27, 2020 10:58:43 PM(UTC)
rachyl1708
Ability to use the rodecaster pro as a multitarck usb device. Just like the Behringer UMC404HD can have each micinput be used as single input and be assign to a camera.
AngusFindlay
#2 Posted : Thursday, March 5, 2020 8:57:46 AM(UTC)
AngusFindlay
vMix supports ASIO. As long as you have your Rodecaster set up the way they describe in this article, you should be able to make it work. I don't have a Rodecaster, so I'm not able to test it myself.
http://en.rode.com/blog/all/RODECaster-Pro-Multitrack
Similar Topics
RodeCaster Pro - Audio routing (General Discussion)
by adambou 2/26/2025 9:35:16 PM(UTC)
Rodecaster Pro 2 Faders Not Working (Hardware Compatibility)
by EZxGHOST 4/9/2024 3:16:00 PM(UTC)
Rodecaster Pro II - New ASIO Drivers Broke Audio (Hardware Compatibility)
by Widget 5/12/2023 10:13:23 PM(UTC)
vMix and RODECaster Pro II settings that works (General Discussion)
by WatsonPrunier 5/8/2023 8:30:55 AM(UTC)
Rodecaster PRO II MIDI (Hardware Compatibility)
by roverradio 1/9/2023 9:03:45 AM(UTC)
Integrating Rodecaster Pro 2 (Hardware Compatibility)
by Widget 12/27/2022 5:51:33 AM(UTC)
Rodecaster Pro II / Multichannel (Hardware Compatibility)
by NTSC 10/31/2022 6:18:09 AM(UTC)
Rodecaster Pro II and Vmix (General Discussion)
by NTSC 9/14/2022 3:30:57 AM(UTC)
Rodecaster Pro And OBS (Hardware Compatibility)
by Powder40 7/16/2022 7:23:24 AM(UTC)
RODECaster Pro Gain Issue in vMix (General Discussion)
by Steve111 2/27/2022 4:39:35 AM(UTC)
vMix Caller hears a tiny echo of himself while talking (working with Rodecaster Pro) (vMix Call)
by Adria07 11/5/2021 3:19:20 AM(UTC)
Audio setup with Rodecaster Pro and vMix Call (General Discussion)
by mnortham 10/10/2019 10:48:54 PM(UTC)
