Using XAML with the multiview
Joined: 1/22/2020(UTC) Posts: 47  Location: Montpellier Thanks: 14 times Was thanked: 2 time(s) in 2 post(s)
Hi everyone ! I'm trying to do the following : Create an input Add to the multiview : 1 - A Background PNG sequence 2 - An XAML animated title The issue I'm facing is that when I cut to the multiview input, the first image displayed is the last image of my XAML title. Here is a video showing it : I might have set something the wrong way ? Thanks a lot ! David
Hi ! Anyone has any idea ?
I have found the solution ! I just had to check "Automatically restart with transition" on the General Settings of my XAML input !
Hope this helps in the future ;)
