Dacast low latency streaming
Rank:: Advanced Member
Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
Anyone gotten it to work? When I get anything going in vMix I still show 30+ seconds. Ditto with Dacast's own branded OBS streamer... Thanks
SOLVED: maybe its a semantics issue, but in the vMix Streaming Settings, manually turn off the second and third stream. Just starting stream-1 will generate other data, so Dacast will not work. Dacast is showing a 10 second latency.
There is also an undocumented (as of now) issue with the Destination address, stream name and/or encoder key. I found this out through the OBS menu which self-populated, as it is not in the documentation. Specifically in vMix, the Dacast stream name can either use an API generated encoder key, or the destination URL needs a full name, indicating not just lowlatency.dacast.com, but also the extension of the server number and name, and the stream number and name.
Hank
