When trying to add a line-in audio input to vMix, I get the following error: Exception from HRESULT: 0x8889000A This only started happening after I updated windows with KB4528760. https://support.microsof...dows-10-update-kb4528760To solve the problem I followed the instructions here: https://www.vmix.com/kno...en-adding-an-audio-inputThis fixes the error issue and allows me to add the input. However, if I restart vMix (not the computer, just vMix) the error happens again.  vMix Pro 23.0.0.39 Windows 10 ver 1909
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
Unfortunately this is not a bug in vMix so there is nothing we can do to fix it on our end. It usually indicates a faulty with the audio device or driver, if it occurred due to a recent update I would advise uninstalling that and also checking the motherboard manufacturer's web site for the latest audio drivers.
Martin vMix
