Hi all!
I am thinking of purchasing a GoPro Hero 7 Silver for an additional input in vMix.
I have the Blackmagic Decklink Duo 2 capture card where I connect my two Sony PXW-X70 Camcorders.
Does anyone know how I can add the GoPro as a video feed possibly through USB or something? I understand the Logitech C920 HD can be connected via USB, can this be done the same way?
Joined: 2/25/2020(UTC) Posts: 18  Thanks: 4 times Was thanked: 4 time(s) in 3 post(s)
Rank:: Advanced Member
Joined: 3/19/2020(UTC) Posts: 36  Location: Kentucky Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Does anyone know how I can add the GoPro as a video feed possibly through USB or something? I understand the Logitech C920 HD can be connected via USB, can this be done the same way? hello, I temporarily used a GoPro Hero 5. which has a 3.0x lens installed. its for sale on craigslist too fo rcheap with that zoom lens installed. You need to buy an Elgato Cam Link 4k... it makes any camera a web cam to your PC... or just get a external capture card. Check you messages here for something cool.
side note. GoPro are meant for outside very bright recording. indoors my quality was always poor due to high ISO on auto settings. very grainy.
