ispyisail
#1 Posted : Friday, February 21, 2020 7:32:41 PM(UTC)
ispyisail
Hi all
From my understand and personal experience one of the problems with RTMP is it needs a good stable internet connection.
I was wondering if I could get a better RTMP feed by using two copies of vmix to live stream?
e.g.
Camera <<SDI/HDMI>> VMix 1 <<SRT>> VMix 2 <<RTMP>> Youtube
VMix 1 - Poor signal area (wifi) (location 1)
Vmix 2 - Good fiber internet connection (location 2)
Just thinking out aloud
Might this work?
MartLeib
#2 Posted : Friday, February 21, 2020 10:03:23 PM(UTC)
MartLeib
Estonia
It works wonders.
thanks 1 user thanked MartLeib for this useful post.
ispyisail on 3/14/2020(UTC)
ispyisail
#3 Posted : Saturday, February 22, 2020 5:12:34 AM(UTC)
ispyisail
Assuming it works as expected the results would have to be spectacular to justify the extra failure points/setup complexity.
Is it possible that SRT is that good?
Speegs
#4 Posted : Tuesday, February 25, 2020 1:09:08 PM(UTC)
Speegs
I do Vmix SRT --> Streaming Server, which publishes to a website (SLDP, ultra low latency), Youtube (RTMP, Low Latency) and Facebook (RTMP, latency is not why, get a lot of viewers on Facebook too lazy to go to a website or Youtube).
This workflow is good, used to use RTMP to the streaming server, have noticed better results going to the server via SRT, particularly on mobile networks which have some packet loss and I'm doing a time sensitive stream so love the latency control in SRT, it's exactly what is needed.
So I say if that works for you do it. It's working around a bad link, best to fix the link. I know only too well however that is not always possible. Sometimes you have to stream with pretty crap Internet. In Australia anyway :)
thanks 1 user thanked Speegs for this useful post.
ispyisail on 2/29/2020(UTC)
mashynewie2
#5 Posted : Saturday, March 14, 2020 12:26:41 AM(UTC)
mashynewie2
Was thanked: 44 time(s) in 33 post(s)
We also do it another way which dramatically increases the reliability of the link.
You really need you head around networking to do it, or spend time on Google.
Buy Cheap Mikrotik
Connect 2 different 4G modems from different providers into the Mikrotik
Fire up Mikrotik CHR on VPS in cloud.
Setup separate SSTP VPN across each 4G link to the VPS
Setup bonding under interface->bonding and make sure it is set to "broadcast"
Then setup the NAT on each router
Route all traffic 0.0.0.0 over the bond.
So what actually happens is that any traffic in any direction is "broadcast" over both 4G links and which ever packet arrives first is passed on to the internet or back towards the encoding computer. The duplicate packet is then dropped.
So as you are broadcasting video, as one network lags the other network will pick up the slack and vice versa.
This sort of set up with 3 different providers in a moving vehicle is one of the most ideal situations for mobile internet, it's almost unbreakable.
The only downside is you use double or triple the data as you data is broadcast over all 4G connections at once.
My recommendation is the HAP Ac2
You are basically getting Teradek bonding quality at the lowest possible price.
thanks 2 users thanked mashynewie2 for this useful post.
ispyisail on 3/14/2020(UTC), adnan_h on 12/22/2020(UTC)
xaver
#6 Posted : Saturday, March 14, 2020 12:41:52 AM(UTC)
xaver
Originally Posted by: mashynewie2 Go to Quoted Post
Buy Cheap Mikrotik
which Mikrotik do you mean?
ispyisail
#7 Posted : Saturday, March 14, 2020 7:08:19 PM(UTC)
ispyisail
