Tally Lights malfunctioning
Joined: 1/16/2017(UTC) Posts: 62 Location: Massachusetts
Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
I just did a WIN7 Pro to WIN 10 Pro upgrade. Everything is working fine except the tally lights and camera names got switched. Easy enough to fix the descriptions but what used to be Green when Live is now orange on both cameras. I found where I can reassign the pin numbers and switched them around and everything seemed fine until I switched to our USB encoder. When I switch to that the light stays green on one camera and off on the other even though I am on the encoder. The CAM 3 position in tally lights is set to none so dont know why it is doing that. It worked fine before the Win10 upgrade. Any help is appreciated. Thanks
