SRT
Larix Screencaster for Smartphone Screen
Hallo Larix ScreencasterWorks also with public IP address. Broadcast like Larix Broadcaster. Also audio transmission. Gruss
All is well with Larix Broadcaster and SLDP pLayer Screencaster: vMix gets stuck of first frame received :-(
Joined: 12/16/2019(UTC) Posts: 87  Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
I don't know where the problem is. I tested all 3 apps for me over the public Internet, and all 3 work fine for me. Screencaster even with videos. The video will of course be sent as a screen. Even with audio. Audio is sent via the integrated microphone in the smartphone and the audio quality is not great on the video screen, but it is acceptable. There is no freeze in the tests I did. If I hadn't tested the apps, I wouldn't recommend them here.You may have to experiment a bit with the bit rates. Sorry mein Englisch, Translator
Elvis55 you helped us a lot, I believe Screencaster is good app and it should work. Something on my end is the problem...will see...
SRT
