AI driven PTZ cam OBSBOT Tail - tracking cam
Joined: 4/23/2017(UTC) Posts: 1,493  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Hi everyone, I stepped into a PTZ gimbal cam that follows you based on AI processing the image data. I thought it sounds too good to be true and tried it. I have to admit that I was impressed by the tracking capabilities. Even hiding behind obstacles doesn't make the cam lose your tracking. You can even walk out of the door and come back and the cam picks you up again. It integrates into vMix via a rtsp stream unfortunately only in 720p. I hope this will increase to 1080p with a next firmware update.
 1 user thanked mavik for this useful post.
I would hope that they could implement both higher resolution and low-latency delivery. Perhaps NDI-HX, since it's Wi-Fi connected.
I guess they focused on the AI tracking function, which is really good. I'm in contact with the support and will see what's on the agenda for improvements. Overall an approach in the right direction.
