h2video.nl
#1 Posted : Friday, January 31, 2020 10:50:21 PM(UTC)
h2video.nl
hi all,
thought I posted this request before, but can not find it: so here it is.
on an input you have the option to seperate the audio channels l and r and control them. great.
but the mute button is still on the stereo input and not on the individual audio channels.
would be great to be able to mute only that specific channel, and be able to assign that to a control button.
would be even better if the mute buttons in general could have a fade out / in option like a transition and set the duration. this way the mute is a fade out or a fase in.
cheers,
stefan
pm
#2 Posted : Saturday, February 1, 2020 6:07:10 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
+1 for specific mute r/l channel (separate mono)
and for consistency reasons:
-shortcuts and activators for r/l channel mute button
-activators for r/l channel faders
mute button with fade in/out can be solved by script.
h2video.nl
#3 Posted : Wednesday, May 26, 2021 2:31:45 AM(UTC)
h2video.nl
any progress on this.
Would be really helpfull.
Plus to avoid scripting: a fade in and out timer would be helpfull, just like with the video transitions you can set a timer. 0 is cut 500 a fade in or out of 500 ms (could be 100 or 1500 whatever).
cheers
Stefan
