vMixxa
#1 Posted : Wednesday, January 29, 2020 8:32:18 PM(UTC)
vMixxa
Switzerland
Hello all,
Is it somehow possible to configure the settings of the integrated CEF component?
When i open chrome://settings in the browser input, all i see is black.
Is there another way of disabling pop ups from websites?
Any help is appreciated. Cheers
mavik
#2 Posted : Wednesday, January 29, 2020 8:44:08 PM(UTC)
mavik
Chrome (Windows)
Click the Customize and control Google Chrome menu (the three dots in the upper right corner)
Select Settings.
Click Advanced at the bottom.
Under Privacy and security, click the Site Settings button.
Select Pop-ups and redirects.
To disable the pop-up blocker uncheck the Blocked (recommended) box.
vMixxa
#3 Posted : Thursday, January 30, 2020 12:35:22 AM(UTC)
vMixxa
Switzerland
Hi, thanks, but i'm trying to do it inside the component of vMix (Browser Input), not Windows. Also, i'm trying to turn on the blocker, not to disable it. Thanks anyway :-)
