Stream FFMPEG audio output configuration
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
As we all know you can set in Stream settings Audio Channels to 2ch ( Master, BusA, etc) and 4ch (MA) and 6ch (MAB).
The bug/problem is when you want to use more than 2ch as FFMPEG uses the default channel layout (FL+FR+FC+LFE+BL+BR).
That layout makes the 4th channel (LFE) useless as it has a low-pass filter.
Is it possible to use channel layout flag -channel_layout octagonal (FL+FR+FC+BL+BR+BC+SL+SR) ?
That way you can use all 6ch audio in FFMPEG rtmp output.
And also include the option MABC in Audio Channels settings?
Thank you!
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
This is not a bug as vMix only officially supports 2 channels for streaming as pretty much all CDNs require this.
Martin vMix
