change box position from variable
Ciao, I'd like to dynamically set the position of a box I can change color, width andh height, but not the position Code:<UserControl x:Class="Box"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
mc:Ignorable="d" Width="1920" Height="1080" xmlns:my="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary">
<Grid>
<TextBlock x:Name="Larghezza" Text="150" Visibility="Collapsed"> </TextBlock>
<TextBlock x:Name="Altezza" Text="220" Visibility="Collapsed"> </TextBlock>
<TextBlock x:Name="PosX" Text="500" Visibility="Collapsed"> </TextBlock>
<TextBlock x:Name="PosY" Text="100" Visibility="Collapsed"> </TextBlock>
<TextBlock x:Name="Colore" Text="#FFFF00" Visibility="Collapsed"> </TextBlock>
<Rectangle Fill="{Binding Text, ElementName=Colore}" HorizontalAlignment="Left" Width="{Binding Text, ElementName=Larghezza}" Margin="{Binding Text, ElementName=PosX},0,0,{Binding Text, ElementName=PosY}" Stroke="Black" VerticalAlignment="Bottom" Height="{Binding Text, ElementName=Altezza}" />
</Grid>
</UserControl>
The error is here: Code:Margin="{Binding Text, ElementName=PosX},0,0,{Binding Text, ElementName=PosY}"
Is there i working solution? I'd like to set X position and Y position in pixel... If possible without code behind Thankyou Marco
