lauraparis
#1 Posted : Tuesday, December 17, 2019 1:23:01 PM(UTC)
lauraparis
On France forums, nobody was able to help me, that’s why I’m trying to find some help here. Even the "professionnals" were not able to give a definitive answer! And I work on this from months… :)
So, I’ll open soon in Cannes a fitness room.
From the HDMI output of my PC (GeForce RTX 2060 WINDFORCE graphic card), I must send the music videos to four 75’’ 4K TVs:
- two TVs located 15 meters (50 feet) away from the PC.
- two TVs located 30 meters (100 feet) away from the PC.
On the TVs, I only play music videos. On my playlist, I have hundred of music videos in mp4 format (3 to 4 minutes each): some in 4K and stereo, some in bad VHS quality and mono. The 4 TVs will always play the same videos at same moment. But without sound, only images. For musics, I’ll install many passive speakers, but I still didn’t choose the sound solution.
1) SEPARATE SOUND AND IMAGE FROM THE PC:
If I understand, I must connect a HDMI cable from my PC HDMI output to the HDMI input of a sound and image extractor. It seems that this extactor must support HDMI 2.0b standard 4K 60HZ 18Gbps signal with 4:4:4 colours and HDCP 2.2 (copy protection). From this extractor, a HDMI output will go to an image splitter or matrix, and an output will go to an amplifier. As I still don’t know which amplifier I’ll use, I still don’t know what kind of sound output this sound extractor must have. I have to find a solution which makes me able to manage the audio signal. For example, if the extractor extracts the audio in stereo signal, if I connect it to the amplifier, what happens? If the extractor extracts in mono, it’s a disaster. So, here are the sound extractor peoples suggested:
Sound: toslink/optical output or 3.5mm analogue output (120 euro):
https://www.keene.co.uk/...-extractor-with-arc.html
Sound: analogue RCA output L+R or digital coax output (120 euro):
https://www.keene.co.uk/...edder-4k-60hz-4-4-4.html
Sound: ???output??? (72 euro):
Sound: ???output??? (67 euro):
https://www.lindy.fr/Ext...3&pi=38171&ci=20
Sound: ???output??? (35 euro):
https://www.amazon.com/O...Extractor/dp/B07BHYXVTY/
2a) SPLIT AND SEND IMAGE TO THE 4 TVs IN CAT6:
Some people told that I had to choose a RJ45 solution. With this solution, some told that I need a splitter, some told that a matrix was necessary. Here are the solutions suggested:
https://www.keene.co.uk/...d-4k-1x4-1-splitter.html (720 euro)
+ 2 x RJ45 CAT6 cables (15 meters)
+ 2 x RJ45 CAT6 cables (30 meters)
https://www.altimium.com...ce-hdmi-hdbaset-4x4.html (3420 euros)
2b) SPLIT AND SEND IMAGE TO THE 4 TVs IN HDMI:
Some people told that HDMI optical cables were the best solution.
They suggested these splitters:
https://www.amazon.com/O...tter-Port/dp/B07HR1WD4S/ (35 euro)
https://www.amazon.com/dp/B07PWYLWLN (45 euro)
http://www.electronicgru...rol-support-4ka60hz.aspx (55 euro) with EDID
http://www.electronicgru...itter1x4-3d-4ka60hz.aspx (66 euro)
https://www.conferencero...m/p/wyrestorm-sp-0104-h2 (150 euro)
With these splitters, these optic HDMI cables are available:
For 15 meters:
https://www.lbm-distribu...soudes/423-uht-15xb.html (280 meters)
https://www.amazon.co.uk...mp;psc=1&tag=av0c-21 (127 euro)
https://www.lindy.co.uk/...-hdmi-2-0-18g-cable-p674
(105 euro)
http://www.electronicgru...-with-amplifier-15m.aspx 15m (70 euro)
For 30 meters:
https://www.lbm-distribu...soudes/425-uht-30xb.html (350 euro)
https://www.amazon.com/-..._encoding=UTF8&psc=1 (100 euro)
http://www.electronicgru...-with-amplifier-30m.aspx (90 euro)
SPLITTER ALL-IN-ONE SEPARATING SOUND AND SPLITTING THE IMAGE:
If the optic HDMI is the best solution, some people told me that this machine does all: separating sound and image (so, the extractor A1 is no longer necessary) and splitting the image:
https://www.ortonsaudiov...with-audio-breakout.html (270 euro)
It seems that if the CAT6 solution is the best one, it seems that this device also separate the sound and the image:
https://www.avacab-onlin...itter-HDBaseT-CSC-70m/en (920 euro)
Some also told that the devices I choose have to manage EDID information and that cables require 1-AMP. That’s why some told me to use this matrix :
https://www.markertek.co...tics-4-coaxial-audio-out (1100 euro)
With 4 recepters:
https://www.markertek.co...ir-rs232-supports-hdr-10 (450 euro)
Also, I don’t know what to do so there is no delay between the sound and the image. Can the audio extractor I choose and/or the splitter I choose insure that they are no delays between the sound and the image? Or is it the job of the sound amplifier? Also, might I use only 30 meters cables instead of two 15 meters cables and two 30 meters cables, so we are totally sure that the 4 TVs are managed exactly in the same manner? One thing is sure: the sound amplifier will have to manage the delay between the two TVs located 30 meters away and the two TVs located 15 meters away.
Last thing: the videos of my playlist are all very different. The whole system must manage automatically the downscaling, upscaling, etc. If I have small 360p videos, for example, I want that they are in fullscreen on the TVs.
Someone told that I have to AVOID that:
- a fiber cable that requires 1-Amp current with a HDMI splitter only outputs 300-ma.
- a splitter not managing EDID globally and only addressing EDID on output 1.
- extracting audio of the HDMI with an external extractor that adds additional delay of the video.
Some help please?
Thank you so much :)
Laura
e.belyshev
#2 Posted : Friday, January 3, 2020 10:09:35 AM(UTC)
e.belyshev
Here is a right way but an expensive method:
santa
#3 Posted : Thursday, January 9, 2020 6:48:56 PM(UTC)
santa
Italy
I don't know why you need an hdmi audio receiver since with a computer as a source you could use a much more affordable and easy to manage system with an amplifier (you can also put a mixer in the gear if you want to) with analogue input (coming from the PC audio jack output). But that's something easily managed in both ways (analogue or digital, consider that many computers have a digital audio output too such as toslink).
I don't know why you need a 4:4:4 and HDCP 2.2 signal transmission to display musical videoclip in a gym.
Try to give a look at products like this: https://www.kramerav.com/it/product/vm-4hdt
1 HDMI 2.0 input, 4 HDBaseT outputs 4:2:0 4K 60Hz HDCP 1.4 up to 40m.
You can pair on TX unit with 4 RX units.
Keep in mind that if you use a computer as a source you don't need to have an HDCP compliant system at all.
