郭子涵
#1 Posted : Wednesday, December 11, 2019 5:29:46 PM(UTC)
郭子涵
China
Hello everyone, I have an electronic timer. How can I synchronize the timer time with the time in GT?
MartLeib
#2 Posted : Wednesday, December 11, 2019 5:54:03 PM(UTC)
MartLeib
Estonia
It depends. What kind of timer is it, what controller does it use? Does it have any input/output, lets say Serial etc.
If it is closed system, then short answer is no, you can not get it to vMix (long answer is yes, but requires time and money). If it has any kind of communication port, then it would be possible to develop agent software and or hardware for your needs.
Easier way would be to use vMix timer input as one of the outputs and show it on the HDMI screen. You can sync up two timers with shortcuts, one is used on the gfx, other to the screen timer.
