Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi all,
I have a list input with let's say 8 audio files, playing loop for a moment before a show. I've assigned a shortcut "play" to the liste, without using the "current video" setting but a specific file. Anyways, it always triggers the selected one in the list tab, but not the one written in the shortcut.
Is that normal or did I miss something ?
vMix 22 4K
Thanks, have a great day !
Joined: 8/5/2017(UTC) Posts: 581  Location: Manitoba Thanks: 121 times Was thanked: 322 time(s) in 184 post(s)
I have not been able to get that feature to work as expected either. I've been using the "ScriptDynamic" shortcut to work around this. First "SelectIndex" command to select the item and then "Play" command.
example:
Function=SelectIndex&Input=2&Value=1 Function=Play&Input=2
 1 user thanked raugert for this useful post.
Hi raugert,
Thanks for your answer. I'm not very familiar with scripts, can you tell me how this work ?
