desktop capture 22 cursor bug
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
noticed I can not disable to show cursor when hardware acceleration is on ( cursor will disapeare when hwa is off ) when viewing in ndi tools studio monitor.
i use desktop capture ( version 22 ) to capture pp and mix this in vmix. but also i use the desktop ndi stream to show the pp on a monitor for the speaker on a seperate laptop connected in the same wifi network. presenters can choos pp only or presenter view ( what a bliss to work with ndi !!)
but i don't want the cursor shown!
greetz stefan
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4739 time(s) in 1626 post(s)
I can confirm unticking Show Cursor in the vMix Desktop Capture settings disables it correctly for both hardware acceleration and off. The only other possibility is you might have some 3rd party cursor software installed on the system that is rendering the cursor some other way.
