mitchellvii
#1 Posted : Monday, November 25, 2019 11:08:43 AM(UTC)
mitchellvii
When I set up my ticker font setting and save the template, the font settings are NOT saved when I re-open the template. I see people posting about this issue years ago and it is still not solved?
#2 Posted : Monday, November 25, 2019 12:18:39 PM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
The old tickers need to be paused in vMix or they won't save in the preset.
Also make sure you are saving the preset, as the original template itself will not be overwritten with these changes.
Or you can try the new tickers in vMix 22 which don't have this limitation.
