mark
#1 Posted : Wednesday, November 20, 2019 8:13:31 PM(UTC)
mark
Have an issue with RTSP video streams coming in and not being recordable with Replay.
I am able to have the 4 RTSP streams come in and switch them fine all in 1080P
The Replay feature is fine with the output of Vmix but even though project is all setup with 1080p throughout the system says the incoming RTSP streams are not the right size format.
Does anyone know how to get around this issue?
Mark
xaver
#2 Posted : Friday, December 6, 2019 7:01:55 PM(UTC)
xaver
Hi
sometimes we have the same problem
check with VLC if the frame rate and size of the stream matches your setup
if not IRP will not record the stream
Guest (4)
