h2video.nl
#1 Posted : Friday, November 15, 2019 5:01:17 AM(UTC)
h2video.nl
searched the forum for this topic, did not find it so I post:
would be nice to have audio transitions plus mix presets ( with fade / transition option in time ) on audio inputs.
I do frequently recordings of events where I use one camera for audio input in 2 channels Left and Right and set vmix input to dual mono. I can then set speaker on 1 and room on 2. when there is a question in the room I mix in the room mic.
i just notice I do the same transition over and over: fade in. room fade out presenter.
would like to suggest two features:
single input mute button under the seperated channels ( there is a mixer but no mute ) that way I turn the input on and of and no need to fade in and out.
more beautiful ( professional ) would be to also have preset options for a specific mix : 1 is speaker on room down 2 is speaker of and r oom on - and a transition time to do the transition.
similar to the video transitions but the for audio.
sometimes the audio comes in from different cameras. so nice if the preset and transition coul be on more inputs.
to be able to mute a channel would be great and if the mute has a fade in and out time even better and presets with transition would just be Whaow fantastic - bananas!!!
stefan
