gerswork
#1 Posted : Friday, November 8, 2019 11:23:15 PM(UTC)
gerswork
Ireland
I am using the "list" feature for playing audio tracks and it would be great to be able to use hotkeys to move up and down the list and play the item selected.
The project at the moment is that I have to play a powerpoint slide show which I can step through the slides using hotkeys, and I have the powerpoint input set to "1" overlay, this allows me to use an input setup with a list of audio tracks that I have to play with different slides from the powerpoint, at the moment I have to use a mouse to select the audio track and play it, from the list menu.
I cannot see the controls of the "list " panel listed in the hotkey selection menu.
Hope to see this feature soon.
BETech
#2 Posted : Friday, November 8, 2019 11:55:51 PM(UTC)
BETech
From the Shortcuts menu, select the Input to your List, and use the Functions “Previous Item” and “Next Item” for the List Input with the audio tracks to navigate up/down the Audio List.
gerswork
#3 Posted : Saturday, November 9, 2019 12:19:15 AM(UTC)
gerswork
Ireland
Hi BeTech
Thank you very much , that worked a treat, i'm still new to Vmix and it may take a while to figure it out.
Cheers
Gerswork
