One small but big problem in 2 persons workflow in livemixing and slowmotion?
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Hello It seems that we can do livemixin with midi mapped keyboard at the same time when other person finds and saves footage from different camera angles for the replay list with mouse and keyboard. No conflicts found yet with simultaneous use of midicontroller and keyboard . The only problem is that in and out points can only be made in "List Delay" window which is located in video preview.
When director person makes direct cut to the other camera angle the previous camera angle will pop up to the preview window as it normally should in video mixer. In this case the person who was marking in and out points in saved videodelay footage in videopreview window will loose the window he was working in. In and out points should be done during the normal camera mixing in order to get highlights video list ready to play when there is brakes in sports.
Is there a way to disable the program and preview window flip flop or may there be an other solution? List delay window with in out point function can not be placed some where else?
One workaround I have found is to midimap specific buttons to mix cameras on layer 1 with direct cuts (in sports fade not needed), then the preview window will stay but then tally lights wont work and transition effect is difficult to implement when moving to replays.
We have vmix4K 12 latest.
