Gyapi
#1 Posted : Thursday, November 7, 2019 8:50:35 PM(UTC)
Gyapi
Hi everybody!
I found an interesting problem, and I don't know where the problem might be.
1. Vmix software 21.0.0.61, H264 encoder 4500 bitrate 1920 * 1080 50p, 128 audio bitrate, baseline 3.1 keyframe 2 sec. (sample, both streams used the same setup)
2. Windows 10 64 Home 18362 build, Google Chrome (also tested under Microsoft Edge)
3. Asus Rog 752 VT, RAM 16 GB, VGA Nvidia 970M, Kemera JVC 600, Sonnet Echo Express - included with DeckLink Duo 2,
4. The phenomenon occurs only in live broadcasts, the archive is OK.
Watch the video:
https://vimeo.com/368472606/572ef65879
The server on the left is my own wowza server, the vimeo on the right, but I could have done a youtube live recording as well.
Before you ask, if sending is not dual stream but only one, the error will still occur.
Could any windows update be the source of the error? Ideas?
Thanks!
Gyapi
sinc747
#2 Posted : Sunday, November 10, 2019 1:18:13 PM(UTC)
sinc747
I would certainly apply all available Windows updates and even update to 1903 and apply all updates for that.
I would also update to vMix 22.
Once I had completed all of that I would test again for this issue. It really doesn't make sense to chase a problem that may have already been solved with updates.
- Tom
Gyapi on 11/13/2019(UTC)
Gyapi
#3 Posted : Wednesday, November 13, 2019 1:14:36 AM(UTC)
Gyapi
Once I had completed all of that I would test again for this issue. It really doesn't make sense to chase a problem that mayu have already been solved with updates.
- Tom
Hello Tom,
Thank you for the recommendation!
Windows and nvidia updated, vmix 22 added.
The situation is only slightly, but better. Not the real thing.
I am more and more sure html5 problem may be the bug.
After all, the signal sent to my own server is good !!
Thanks,
Gyapi
Guest (4)
