shawntempesta
#1 Posted : Wednesday, November 6, 2019 11:24:41 AM(UTC)
shawntempesta
Was thanked: 9 time(s) in 7 post(s)
Would be great to be able to select "Automatically Reset with Pause".
The use-case... a music sting and bed. You stop it. The next time you fire it you want it to start from the top.
"Automatically Restart With Transition" does the job IF I am putting the audio in the program monitor. But I am playing it direct from a button bar, not taking it full.
shawntempesta
#2 Posted : Wednesday, November 6, 2019 11:27:30 AM(UTC)
shawntempesta
An easier fix to this would be a "PlayFromBeginning" function.
#3 Posted : Wednesday, November 6, 2019 2:47:30 PM(UTC)
Trigger or shortcut it with a "restart" ?
