Speegs
#1 Posted : Tuesday, October 29, 2019 4:56:40 PM(UTC)
Speegs
I usually use a 640x360 setting for a low quality RTMP stream. However that option is not available in SRT under the resolution drop down.
SD uses a 4:3 mode (576p), so I can't use that.
HD720 is fine.
The 360p setting is useful in an adaptive bitrate scenario. I want to send 2 streams from Vmix to an SRT Server (Nimble) which works, but I want one to be 360p.
Seems there is no "Custom" option, that would be appreciated. Or SD360 which is what I often use as the very low quality option.
