Amokka
#1 Posted : Monday, October 28, 2019 7:30:47 AM(UTC)
Amokka
Was thanked: 18 time(s) in 13 post(s)
Currently, the only way to select multiple replay events for playout,
is to hold down Ctrl-key and use mouse to select events or, use SHIFT-key + mouse.
It would be really nice to have the ability to select multiple events.
Preferably. Events can be marked in/out using both mouse and shortcuts.
I imagine that it would be somewhat simple to implement, by adding another column with checkboxes in the replay event list.
Then, using either mouse or shortcuts, you can move up and down the list.
New shortcut can then toggle the selection checkbox for each event - similarly to the way one currently select camera angles.
This makes any sense?
Best
J
thanks 1 user thanked Amokka for this useful post.
nc on 11/4/2019(UTC)
nc
#2 Posted : Monday, November 4, 2019 8:16:40 PM(UTC)
nc
+1 shortcut to select multiple replay events for playout
dmwkr
#3 Posted : Thursday, January 30, 2020 1:46:54 AM(UTC)
dmwkr
+1
mavik
#4 Posted : Thursday, January 30, 2020 6:00:08 PM(UTC)
mavik
+1
Mikhelson
#5 Posted : Friday, March 1, 2024 3:46:36 PM(UTC)
Mikhelson
Kazakhstan
Is it possible now?
Mikhelson
#6 Posted : Sunday, August 9, 2026 10:03:58 PM(UTC)
Mikhelson
Kazakhstan
Following up on this request now that vMix 29 has been released.
It is still impossible to select multiple Replay events using only a keyboard, MIDI controller, Stream Deck or other external controller.
During live sports production, an operator often needs to quickly select two or three events and play them consecutively using ReplayPlaySelectedEventToOutput without touching the mouse.
Please add shortcut support for extending or toggling the event selection while navigating, for example:
- ReplaySelectNextEventAdd
- ReplaySelectPreviousEventAdd
- ReplayToggleCurrentEventSelection
Alternatively, a multi-select modifier mode for the existing navigation shortcuts would work well.
A ReplaySelectLastEvents or ReplayPlayLastEventsToOutput shortcut with Value specifying the number of recent events would also be useful.
This would allow Replay operators to work entirely from a hardware controller during live production.
