chrissabato
#1 Posted : Thursday, October 24, 2019 3:34:50 AM(UTC)
chrissabato
My data source in vmix is only updating every 2 seconds despite being set to update faster. I've tried 1000, 500 and 100 with the same result. Is there a setting I'm missing? I have basically the same setup on a different pc that works fine.
Video Example
#2 Posted : Thursday, October 24, 2019 12:07:39 PM(UTC)
The data sources window will only update every couple of seconds for performance reasons, but the title itself should be a lot faster.
I can't see in the video which data source controls the clock, but maybe it is set to something other than 500ms?
In any case, please drop us an email and send a support report for Settings -> About and we should be able to work out what is happening.
MThomas56
#3 Posted : Tuesday, January 7, 2020 6:25:05 AM(UTC)
MThomas56
Curious as to what the solution may have been for this. We had similar issues with our Data being slow to change and differed on multiple PC's with the same projects.
Matt
chrissabato
#4 Posted : Tuesday, January 7, 2020 6:28:10 AM(UTC)
chrissabato
Ultimately Windows was the issue, more specifically, the drive format. Reformatting the drive to NTFS solved my issue.
