Simsyuk
#1 Posted : Friday, October 18, 2019 7:02:41 PM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Hi all, a friend has offered me the following capture card and I wondered if anyone has used this? It's not on the compatible list but I thought I'd ask on here just in case.
Visimetrics Video Input Card Iss 3 PCI 4x BNC Video Input Card
Found the same one on ebay:
https://www.ebay.co.uk/itm/253994331448
zenvideo
#2 Posted : Friday, October 18, 2019 11:04:46 PM(UTC)
zenvideo
What can your friend tell you about it, and its drivers? How does it show up in Windows Device Manager? My guess is that has four analogue composite inputs, and is a single channel card in which one of the four inputs can be selected at a time, as might be used for recording multiplexed CCTV.
Simsyuk
#3 Posted : Saturday, October 19, 2019 3:51:41 AM(UTC)
Simsyuk
He bought a secnondhand PC with the card inside. He's taken it out as he doesn't want or need it. I suppose I'll just install and see what happens, thanks for replying zenvideo.
