vMix not detecting ANY displays - solved
I don't know why this is happening. I bought the $350 HD version. Now I can't detect ANY displays when I hit the dropdown box next to "fullscreen." See here: https://gyazo.com/0666ee33ee701e5e3218dd5e3434cba3How do I set up multiple displays? Please help.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Say its a laptop 1 will be the laptop display , 2 the attached second display  display.JPG (55kb) downloaded 2 time(s).
Originally Posted by: doggy  Say its a laptop 1 will be the laptop display , 2 the attached second display  display.JPG (55kb) downloaded 2 time(s). Vmix is only picking on one display. See here.
change the number to one
Believe HD is only able to display fullscreen to one display
Originally Posted by: doggy  change the number to one
Believe HD is only able to display fullscreen to one display Okay, what's the plan that allows displays to more than one?
i would say connect more ?
but seriously
what are you using? desktop, laptop ? if desktop what is your graphics/output card etc (for the hardware buffs) Maybe start of with the basics first to have full screen at all on you current base monitor ? what do you want to be displayed on each when you want to go to more then one ?
Originally Posted by: doggy  i would say connect more ?
but seriously
what are you using? desktop, laptop ? if desktop what is your graphics/output card etc (for the hardware buffs) Maybe start of with the basics first to have full screen at all on you current base monitor ? what do you want to be displayed on each when you want to go to more then one ? Nvidia graphics card. I'm using a PC. I have 4 monitors connected. Yet it only gives me one display option.
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
In the latest screenshot posted, you have the Display drop down box underneath the big green Display1 button. That is what you need to change to select the display for the Fullscreen output, not the green button.
