Hardware Compatibility
Black Magic Intensity Pro - Camera image duplicated in vMix
Joined: 10/13/2019(UTC) Posts: 6  Location: Seattle Was thanked: 2 time(s) in 2 post(s)
I searched and didn't see anything on this topic.
I have a intensity pro pci card, with video camera attached. vMix sees it just fine however the video image is duplicated horizontally.
This occurred when testing in LiveStream as well so I know it's not a vMix issue, I just can't find any setting for this. This does not happen in the Black Magic software either so no sure where or how to fix this.
Thank you in advance for any help!
I figured it out. Found that the default setting vMix was using did not match the camera output. Once I changed that, problem solved.
