Why facebook has not received video signal ?
I streamimg to facebook but facebook live interrupted this is log from facebook => "Facebook has not received video signal from the video source for some time. Check that the connectivity between the video source and Facebook is sufficient for the source resolution and bitrate. Check your video encoder logs for details. If problems persist, consider improving connection quality or reducing the bitrate of your video source."
But i switch live FB another page isn't interrupted
Joined: 10/17/2019(UTC) Posts: 1  Location: Kozukue-cho, Kohoku-ku, Yokohama
Hi, I have same problem.
Also I'm trying to stream Facebook live in Facebook Group and page, but it doesn't work and shows the same error log - facebook has not received video signal from the video source for some time. check that the connectivity between the video source and facebook is sufficient for the source resolution and bitrate. check your video encoder logs for details. if problems persist, consider improving connection quality or reducing the bitrate of your video source.
Please let me know how yo can find the solution to stream LIVE in another page.
Atsu1166
