millst
#1 Posted: : Tuesday, October 8, 2019 9:34:06 AM(UTC)
millst
Was thanked: 7 time(s) in 3 post(s)
Normally I use ASIO in VMix for DVS.
However, recently, I also needed to pull audio from Spotify on the same PC so I was forced to use WDM.
The audio just pops and clicks and glitches in VMix whenever you use the WDM driver in VMix.
Has anyone else had this issue. I know ASIO is preferable for a host of reasons, but sometimes you have to use WDM.
All other audio sources on the PC seem fine with WDM, its just VMix that doesn't seem to like it.
Daissy
#2 Posted : Sunday, September 27, 2020 1:45:15 PM(UTC)
Daissy
When it comes to Spotify, you shoud know that it doesn't allow users to use its music on other devices or platforms. But don't worry. There are tools like DRmare Spotify Converter, DRmare Audio Capture, etc. that can help you get Spotify music on the devices you want as local files. Just give it a try and see how it work.
