Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
I went through an issue a couple of months earlier : I output my signal to a video projector which was located on the ceiling of a room, and had audio embedded within HDMI. Since I was using Master and A buses, I had to use the B bus to feed this machine, because the guys couldn't find the remote control and cut the sound... so if I had the possibility of sending silence ti the output in the settings menu, that would have been great (instead of just M, A, B, MA...).
Thanks and keep on going !
