Joined: 2/2/2019(UTC) Posts: 13  Was thanked: 2 time(s) in 1 post(s)
Is there a way to get status of an input/overlay etc via TCP API?
I'm writing just macros script and I can successfully send commands but I do not understand how to receive/get status of current Active input,Preview input etc.
Thank you
I've figured it out so here is a snippet if someone needs it: Code:
function GetValue(string, num)
if string == "active" then
RawCommsNetSendString( Vmix, "XMLTEXT vmix/" .. "active" .. "\r\n")
elseif string == "preview" then
RawCommsNetSendString( Vmix, "XMLTEXT vmix/" .. "preview" .. "\r\n")
elseif string == "overlay" then
RawCommsNetSendString( Vmix, "XMLTEXT vmix/" .. "overlays/overlay[" .. num .. "]" .. "\r\n")
--elseif stringe == "" then
-- RawCommsNetSendString( Vmix, "XMLTEXT vmix/" .. "" .. "\r\n")
end
Sleep(10) -- wait 10ms before grabbing data
receive = RawCommsNetGetIncomingPacketCount( Vmix );
data = RawCommsNetGetInPacketAsString( Vmix, receive )
--VSLog( data )
data = data:sub(12) -- TRIM XLMTEXT OK
VSLog(string .. " " .. data)
return data
end
 2 users thanked gokily for this useful post.
