Rinsky
#1 Posted : Thursday, September 26, 2019 7:12:07 AM(UTC)
Rinsky
I just saw the layout of the new additional audio busses c,d,e,f,g and that you have to right click on the old busses du select/deselect the new ones. (I know it's not even in beta...so sorry if the post is redundant and you want to change that anyway)
Tom Sinclair Audio Bus C-G
Please make it more something like one of those two examples:
Audio Busses C-G examples
It would be way easier to change them on a live production and to see which ones are selected and which ones are not.
sinc747
#2 Posted : Thursday, September 26, 2019 8:05:01 AM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Is this a new vMix Hand Model?
vMix hand models
richardgatarski
#3 Posted : Wednesday, October 2, 2019 7:30:24 AM(UTC)
richardgatarski
+1
I would prefer vertical arrangement. To make room the bus buttons could be a little bit smaller, and the width of the level meter could be decreased.
xztraz
#4 Posted : Wednesday, October 9, 2019 9:09:44 PM(UTC)
xztraz
Sweden
+1
maybe a setting for which buttons that should be visible then you can have a clean layout for simple jobs and go full bananas when doing something more advanced.
Also a setting if the buss mixes should be pre/post fader. very useful for talkback and such.
and pfl(bus)... and gain first in the chain and so on. there are some quite fundamental things missing from vmix that is used in production environments so far, but its getting there.
ralston
#5 Posted : Monday, April 13, 2020 4:07:07 AM(UTC)
ralston
Sounds like a great idea to me ! anything that makes it easier to see BUS allocation during a live production would help. Currently using the BUS's for independent talkback to vMix callers before we take them to air in the main TX.
pm
#6 Posted : Tuesday, April 14, 2020 2:15:18 AM(UTC)
pm
You have been a member since:: 11/28/2015(UTC)
Was thanked: 33 time(s) in 28 post(s)
+1
MartinHH
#7 Posted : Tuesday, April 14, 2020 8:41:36 PM(UTC)
MartinHH
Germany
+1 and please add all audio settings and busses to the Virtual Control Surface
vmixusersrb
#8 Posted : Thursday, April 16, 2020 3:38:32 AM(UTC)
vmixusersrb
Serbia
+1 One more thing I would love to also bring (like you have M button on A channel) G to A, or B to A... This would be great option.
umek
#9 Posted : Saturday, April 18, 2020 12:49:52 AM(UTC)
umek
+1
KMR
#10 Posted : Saturday, May 2, 2020 7:07:26 AM(UTC)
KMR
Ireland
+1
