MultiviewOverlay Turn On/Off Input with Transition Effect?
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
Hello, I have 1 multilayer input with 3 different backgrounds that got changed from time to time. I mapped shortcuts to turn on/off certain inputs. But it seems it only cuts when you do so. Is it possible to set transition in/out effects to this action?
Em....I also need this effect.
Joined: 2/18/2018(UTC) Posts: 28  Location: Milan, Italy Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
This could be a fantastic new feature!
Originally Posted by: andreypetr  But it seems it only cuts when you do so. Is it possible to set transition in/out effects to this action? The short answer is No. There is only one "M/E" bus where you you can use transition FX, and that's on the main "Program" feed. You can't also have transitions upstream of this within a Multiview. However, you can create two almost identical Multiviews, using the same combination of layers (except the one which you are toggling on/off), and then transition between those two input versions, which will at least allow you to have a layer fade in and out for example, even if the whole process is not as straightforward or as versatile as having multiple M/E busses. But that's how it is right now, and in the world of hardware video switchers you pay a lot more for having multiple M/E buses on the switcher.
