MarkNF82
#1 Posted : Wednesday, September 4, 2019 2:30:48 AM(UTC)
MarkNF82
Canada
Was thanked: 6 time(s) in 4 post(s)
Hi Everyone,
Sorry I don't have a screen shot at the moment, but this happened on our church vMix system at various times.
We are using one of the vMix included lower3rds on our welcome page before the service begins. A couple of times now, the text on the lower 3rd graphic displays as "Headline / Title" instead of the text that is actually in the title window. Trying to change it live or with data source, or list text has no effect on it either. Only thing to do is close vMix and open again and it may or may not correct itself.
vMix 22.0.0.67
Has anyone else had similar behaviour? I will provide screen shots at our next service if it happens.
Mark
#2 Posted : Wednesday, September 4, 2019 2:41:35 AM(UTC)
by trying "Trying to change it live" do you mean the live button is active ?
MarkNF82
#3 Posted : Wednesday, September 4, 2019 2:54:32 AM(UTC)
MarkNF82
Canada
I hope for my sake it is. I always use live mode so if it is turned off it is by pure accident. However, seeing that closing and opening vMix usually fixes it, hopefully it's not as easy as that, unless I got duplicate presets with different settings for some reason.
This may be an ID 10 T error.
I'll have to check at the next service.
#4 Posted : Wednesday, September 4, 2019 4:21:37 AM(UTC)
Would also check any shortcuts that might interfere with the title
as silly as it sounds but like ResetInput or that trigger any title presets or having the title more than once and trying to change the wrong one
