Joined: 2/14/2018(UTC) Posts: 11 Location: Philippines
I love this new feature - it really cleaned up my audio mixer console.
However, rarely, I might need to make an adjustment to audio settings for one or more inputs that are otherwise hidden from the mixer. If this is checked, you have to open the settings from the input then choose audio settings, uncheck the Visible flag, etc. for each affected input. Then go back and check them all again...
It would be helpful if, in the Audio Mixer window itself, there were a checkbox, toggle button, or context menu option that would show all inputs regardless of the "visible" flag. That way, all inputs can be available for as long as needed (including easy access to the visible flag) and then by unselecting the option, the mixer would revert to "visible" items only.
